This command allows the unconfiguring a per-port meter for one set of ports but not another.
ports | Meter configuration is applicable to ports in the specified port_group or port_list. |
port_group | Port group name. |
port_list | Port list separated by a comma. |
N/A.
With global meters, there is no need for an unconfigure command as the user can simply delete the global meter to remove the configuration. However, the per-port meters are created by default (e.g. ingmeter0, ingmeter1…) and cannot be deleted. This command allows the unconfiguring a per-port meter for one set of ports but not another.
unconfigure meter ingmeter1 ports ingMtrGrpA
This command was first available in ExtremeXOS 16.1.
